strange 12bolt vent??
hey guys... im still working on my rear and because i bought it used i wanted to make sure the vent is cleared so i dont blow a seal or anything... but i cant seem to find the vent in it... they are usually in the axel tubes but i dotn see them there... does anybody know where the vents are for a strange 12 bolt rear? i did a search and found nothing on this .... thanks
well i found the vent so N/M on that... its a weird looking screened bolt... i was looking for a normal nipple fitting style bolt that a hose would hook too... but i do need the torque specs for an aluminum 12 bolt girdle cover... i need the spec for the cover bolts and also the spec for the preload on the bearing girdles and lock nuts... thanks if anybody knows this
