Gear guru's...check this out
Old 12-22-2009, 06:33 PM
LS1-IROC's Avatar
Default Gear guru's...check this out
Is this pitting on the tooth face normal? I just bought a used 9inch rear with only 500 miles on it...I pulled it apart and found this. It's a US gearset and currently has .010 backlash in it.
Old 12-22-2009, 06:48 PM
kenSS's Avatar
i never seen it before.
Old 12-22-2009, 06:59 PM
shtnfrds's Avatar
IVE NEVER SEEN IT BEFORE AS WELL, but i imagine surface irregularities like that cant be good on such a high stress part.
Old 12-23-2009, 01:32 AM
Zmg00camaross's Avatar
All most like gears got wet and rusted a little and then where used and again, and pitted the gears. Thats a guess but either way i wouldnt use them probly make noise. and gears a cheap enuff.
Old 12-23-2009, 06:27 AM
cambirdracing's Avatar
It will also create stress risers and probably bust a few teeth off of it.
Looks like it has been out in the weather for aa while.
Old 12-23-2009, 04:19 PM
LS1-IROC's Avatar
The rust idea makes some sense, but the wierd thing is that the pitting is only on the coast side of the tooth...The drive side looks fine. I just wonder if the guy I bought this from had a used ring and pinion set installed when he had the rear built.
Old 12-27-2009, 03:23 PM
LS1-IROC's Avatar
I tore the diff all apart and confirmed the pitting was from rust on the tooth surface. I looked at the pits under 10X optical zoom and you can clearly see the rust. Also found rust pitting on the pinion support bearing races.
So guess I'll be buying a new gearset.
Old 12-27-2009, 06:12 PM
RsSean's Avatar
Looks to me that the metal is pitting, maybe to lack of fluid. See that a lot in the axle shaft where the outter bearing rides when there is a lack of lube.
Old 12-27-2009, 07:51 PM
supermouse4's Avatar
From the looks, there is rust on the gears. Change the gears to ensure that you don't have gear failure from the pitting and stress risers.
