12 Bolt Moser Rear Fluid Change
Old 01-11-2010, 11:16 PM
Midnight00SS's Avatar
Question 12 Bolt Moser Rear Fluid Change
What kind of fluid can i use in here? do i run synthetic or reg? i also have a HD eaton posi unit in it, i dont wanna hurt nothing
Old 01-14-2010, 03:12 AM
Zmg00camaross's Avatar
I would probly use a 75w90 non synthetic and use limited slip addtive.
Old 01-14-2010, 05:31 AM
EPP
EPP's Avatar
Moser wants you to use a non synthetic gear oil. Napa 80/90 weight non synthetic gear oil does the job. As has been mentioned, pick up a tube a posi additive, some call it friction modifier. Bob
Old 01-14-2010, 05:00 PM
J&J Speed Shop's Avatar
With the Eaton Posi you will want to use non-synthetic 80w90. Any decent brand will do. Also pickup a bottle of GM #1052358 from a local GM dealer. Trust me when I tell you to get the GM brand Limited Slip additive
Old 01-14-2010, 11:26 PM
got it and changed it, thank u guys
Quick Reply: 12 Bolt Moser Rear Fluid Change
