MWC driveshaft loop won't fit - LS1TECH
Thread Tools Search this Thread
Old 01-16-2010, 06:34 PM   #1
RsSean's Avatar
Default MWC driveshaft loop won't fit
I have tried different ways of installing this thing and it either hits the body or it hits the exhaust anyone have any pics that may help me out.
Thanks
RsSean is offline   Reply With Quote
Old 01-17-2010, 02:47 PM   #2
RsSean's Avatar
Bump someone has to have some insight on this.
Old 01-17-2010, 03:27 PM   #3
I had the same problem due to my stock y pipe. I took and shaved a half moon shape into the vertical brace on the loop.
boss79z is offline   Reply With Quote
Old 01-17-2010, 03:28 PM   #4
This is the best picture I got man.
Old 01-17-2010, 05:37 PM   #5
LS1Tech Premium Sponsor
ssvert99's Avatar
do you have just the d/s lop or is it a torque arm/crossmember assy?
the d/s loop by itself is designed to lay right on the sheetmetal of the tunnel. start(don't tighten) one side of the bolts, push it up into the tunnel, and then start the other bolts. this is the way it is designed, allow for the most exhaust and torque arm clearance, and not hang low/under the exhaust like all the other designs out there that drag the ground or your trailer.
ssvert99 is offline   Reply With Quote
Old 01-17-2010, 08:11 PM   #6
RsSean's Avatar
Yes I got the DS loop brace only. I figured that is the way it was supposed to go but was not willing to have it resting on the body of the car. Thanks
It the brake lines supposed to be on the inside pinned agasint the body or on the outside.
Old 01-20-2010, 12:35 AM   #7
cookba's Avatar
mine didnt fit either with my GMMG exhaust and Kooks headers. gonna have to put it back on a rack and see what i can do.
cookba is offline   Reply With Quote
Old 01-20-2010, 10:16 AM   #8
hokie00 TA's Avatar
i had to grind a notch in mine so it would fit around the exhaust
hokie00 TA is offline   Reply With Quote
Old 01-20-2010, 02:10 PM   #9
WARP211's Avatar
Most likely it won't fit unless you modify the exhaust to get it up higher in the tunnel area.. I had the same problem wit UMI DSL setup and just sent it back and got something else. My setup was ARH headers with their catted Y-pipe.
WARP211 is offline   Reply With Quote
Old 01-20-2010, 04:33 PM   #10
Giddswat's Avatar
I have the MW d/s loop and at first it rubbed the exhaust a little bit, I have Kooks L/T and a Borla exhaust. We just had to loosen all of the exhaust clamps and mounts and used a ratchet strap to pull the exhaust away and re tighten everything back up . I have not had a problem since. I mounted the fuel line on the outside, I was concerned about rubbing a line thru. You have to remove a fuel line clamp or two and just re secure the lines on the outside.
Giddswat is offline   Reply With Quote
Old 01-21-2010, 09:42 PM   #11
RsSean's Avatar
I just said the hell with it and set it aside for now, till I go to the track and I will find a way to mount it for the track
Related Topics
Thread Thread Starter Forum Replies Last Post
rockers hitting valve covers codymx29 LT1-LT4 Modifications 3 04-26-2012 09:06 AM
Cam with great drivability abates LT1-LT4 Modifications 31 12-15-2010 10:34 PM
idler hits bracket pdasterly Generation III External Engine 8 04-09-2010 06:12 AM
anyone have a stall? chevyrunner Western Members 6 02-25-2010 11:50 PM
Header hitting the steering shaft!! True Performance Generation III External Engine 7 03-20-2007 11:03 AM
Tags
arm, bmr, chassis, drive, driveline, driveshaft, fit, loop, midwest, mwc, shaft, silverado, torque, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
