Driveshaft Length???
Old 01-26-2010, 05:53 PM
94TRANS's Avatar
Default Driveshaft Length???
Does anyone know the length of the stock driveshaft on the LS1 F-Bodys with 4L60e tranny and stock rearend? lookin gto buy a new one and need to know i think iv read before that its 42.5" but am not sure... thanks for any help.
-Kris
Old 01-28-2010, 10:33 AM
94TRANS's Avatar
anyone?
Old 01-28-2010, 06:39 PM
Camaro Junky's Avatar
Well I just measured my drive shaft because it is way too short for my new Ford 9. I measured from the very edge of the the U joint on the rear of the drive shaft to the edge of my 4L60E. I got 45 inches. Though I could not measure to the end of the yoke, because it is still in the tranny. I hope the helps.
Old 01-28-2010, 09:29 PM
SS SLP2's Avatar
I am Y2K SS 4L60E stock 10 bolt, OE 3" alum drive shaft from center of ujoint to center of ujoint I am 41"
Johnny
Old 02-02-2010, 08:47 PM
mikey1107's Avatar
I had the same question and have never been able to find a definitive answer.I get 42.5",41",45"...etc.
Does anyone have a stock LS/4L60 driveshaft sitting around that they can measure from the center of the front joint to center of the rear joint?
Old 02-02-2010, 10:03 PM
SS SLP2's Avatar
stated in reply # 4
Johnny
Old 02-03-2010, 12:44 AM
94TRANS's Avatar
Johnny
yea that seems about right knowing that iv read 41.5" before, thanks for the reply!
does it really matter if its off just barely like a half inch at most?
Old 02-03-2010, 07:14 AM
mikey1107's Avatar
stated in reply # 4
Johnny
I wasn't for sure. I had never seen a driveshaft type or talk so I wanted hear it from a human.
Thanks for the info.
Old 02-06-2010, 07:58 PM
I just measured mine, it is for an A4. 47 and 3/4 inches. From tip to tip.
40 and 3/4 inches from the middle of the rear U joint to the middle of the Slip yoke U joint.
Attached Thumbnails Driveshaft Length???-p2060121.jpg   Driveshaft Length???-p2060122.jpg
The following users liked this post:
MuffinMunford (01-26-2022)
Old 02-06-2010, 09:22 PM
SS SLP2's Avatar
I am qurious as to why we ( several of us) are getting differant leights, some 41,41 1/2, 41 3/4 center of u joint to center of u joint,( I went back and chk again) I am sure we all are capable of reading a tape, please post up year and transmission. I thought all Z 28-SS a4 or 6 spd 98-02 were the same,. I could understand if we were checking a v 6 or other year models
as I stated on post # 4 my SS is 2000, a4 came stock with 3.23,bough new I helped unload it from the transport. Please post up and see if we can find a reason for the differant answers
>> Mr. OP I am sorry for steping on your post, but I would like to know that you are getting the correct answer
Johnny
Old 02-07-2010, 05:25 AM
EPP
EPP's Avatar
Being off .5 should not hurt anything. You want to make sure it cannot bottom out from being too long, and if it is too short it can cause a drivetrain vibration, and can cause what splines that are engaged to become twisted. Bob
Old 02-08-2010, 12:50 PM
mikey1107's Avatar
Johnny
Thats why I was asking also. I get several different answers. I want to be sure when I go to have a driveshaft made that I have the correct measurements and not just a guess or "some guy said it was" It seems 41.5"-42" center to center seems to be the most common answer. I guess 41.75" would be a safe bet.
Old 02-08-2010, 12:54 PM
mikey1107's Avatar
Zooming in on your pic it looks like about 42.5 center to center.Is that what i looks like to everyone else?
Old 02-11-2010, 06:27 PM
Amigo, measure the drive shaft the way the shop measures.... It looks like they all have their own way of doing it too. For example, A shop in SA wanted me to measure from the rear tranny seal to the middle of the rear U joint.
I bet you call a shop and you will get something different...
Quick Reply: Driveshaft Length???
