Quick Performance Ebay 9 inch
Anyone running one of these?
You can get the housing with all brackets and either Moser or their axles for a G.
Not bad considering you could go to the junkyard and find a 3rd member for a couple hundo and there you go.
9inch for under 1500
You can get the N bare case from them for about 229.00 or their alu case for about 329.00 ,then find a junk yard 3 rd member with 31 spline pull the guts out and install in the N case or alu case , you may like to try their pinion support also for about 90.00, may also buy a 1 " longer yoke so you may run your OE drive shaft ( if you are brave enough to try the OE )
They as are our other great vendors are great to deal with.
just my .02' Johnny
just my .02' Johnny
I broke a broke a pinion once in a regular case 9 "......is a gn that went 9.80's . You guessed it, stock oem 3.50 gears leaving off a trans brake at 12 psi on et streets.
I went 10.00 @135 in Zombiess car, with a regular NON N case 9 in it. It weighs 3890 with me in it, of the trans brake. It also has 100's of trans brake leaves on it. Not that they dont break, but deffinately not something for most people to worry about.
