Broken lug stud help!!!!
Ok so I have a 02 ls1 ta auto with traction control. OK here is my problem I lost my rear driver side wheel the other day on the freeway. I have 4 broken studs. I cannot figure out how to replace them without taking the rear end apart. I have had a mechanic look at it and he said the same thing. I cant remove the lug because the abs sensor wheel is in the way. Does anyone know how to change these out??? I dont have the money to upgrade to another axle so I am stuck fixing this. My mechanic said he can do it for 120 labor, 25 for lugs and studs, and he said that my abs sensor is broke so 109 for that, and that i might have messed up an axle shaft. I also found a new 10 bolt out of a fire hawk for 300 should I just buy this and put it in? i am lost any help with be great.
thanks
thanks
Like stated, remove the sensor then drive the broken lug studs out with a hammer through the sensor location. Then use an old lug nut to pull the new ones through the hole. Ive done it on my 98 Trans AM twice.
