Easy to go from 1/2" to 5/8" studs on the axles?
Old 02-18-2010, 08:46 PM
scidav87's Avatar
Default Easy to go from 1/2" to 5/8" studs on the axles?
Silly question i guess. All you need to do is just drill and tape the axles for the 5/8" studs right? Or should i just leave in 1/2 wheel studs with my 700 HP M6 car?? Will factory 10 spoke SS wheels work with 5/8" studs?? THANKS!!
Old 02-19-2010, 06:00 AM
cambirdracing's Avatar
I would leave the 1/2 in there. Don't think factory wheels will fit over the 5/8.
Old 02-19-2010, 06:04 AM
SSdreamz's Avatar
factory wheels will not fit over 5/8 inch studs
Old 02-19-2010, 08:14 AM
Big_Bird_WS6's Avatar
5/8" WILL fit in stock rim.
-first picture is a 5/8" stud in stock 17" trans am rim.
-second picture is stud with lug nut in stock 17" trans am rim.
-last picture is with the socket on it so you can tighten it down.
and i ordered my axles with both 1/2" and 5/8" patterns in them. so i have 1/2" in there now. an d when i go faster i can switch out to 5/8"
Attached Thumbnails Easy to go from 1/2" to 5/8" studs on the axles?-stud-stock-rim.jpg   Easy to go from 1/2" to 5/8" studs on the axles?-stud-nut.jpg   Easy to go from 1/2" to 5/8" studs on the axles?-stud-socket.jpg
Old 02-19-2010, 08:16 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Assuming this will be on a soon to be bought 9".
You will bend/break your factory studs if you actually try racing it and you maybe in the situation where you are going fast enough need longer/thicker studs.
My 12 bolt is drilled for factory, but when I upgrade I will have them modded for 5/8" They are going to be placed inbetween the factory drilled holes and just remove the 1/2" stuff.
Old 02-19-2010, 08:52 AM
ryarbrough's Avatar
Wrong.... We slapped my stock formula wheels on MIGHTYMOUSE's car for the drive to Memphis last year (raining like hell and didn't want to be on DR's). He has 5/8 studs.
Old 02-19-2010, 02:57 PM
well maybe the 16" wont. but my 17" stock CETA rims. and my bros stock 17" ws6 rims both bolt right on. so IDK
Old 02-19-2010, 04:02 PM
SSdreamz's Avatar
tried my brothers 16" factory camaro wheels on a 12 bolt he bought from stangeater01 on here thats has 5/8 studs, and it will not fit.... just going from experience with that. dont know about the 17 inch wheels but didnt think they were different
Old 02-19-2010, 09:07 PM
Vindictive98LS1's Avatar
dont mean to high jack this thread but can you take out 5/8" studs and put in 1/2" studs?
Old 02-19-2010, 11:41 PM
ryarbrough's Avatar
stock formula wheels are 16's... The camaro wheels should also fit.
Old 02-25-2010, 05:41 PM
i guess no one knows the answer to that question?
Old 03-15-2010, 11:17 PM
tomz28's Avatar
that was after you drilled them out right? because i have some ZR1 wheels that need alot of work to fit on my studs. i can not find a nut to fit in the rim pocket.
Old 03-16-2010, 06:05 AM
Never seen it done. the hole is 1/8 bigger. You would need to have the shoulder on a 1/2 stud 5/8. don't remember anybody making those.
Old 03-17-2010, 09:03 AM
tomz28's Avatar
why would you want too? thats a big down grade>
Old 03-18-2010, 09:08 AM
b/c i got a used rear with the 5/8 studs and they wont fit over my rim or my rotors. anyone drill out the holes on your wheels and/or rotors?
Old 03-20-2010, 05:13 PM
tomz28's Avatar
just got my ZR1 wheels on the car had some spacers made on a lathe. i have the specs if anyone needs them.
ill put up pics soon. i got this idea from Hunter02ss thanks buddy
Old 03-08-2011, 10:23 AM
25thhawk's Avatar
for those that have fit the stock wheels over the 5/8 studs, what lugnuts did you use? 5/8 acorn style?
Old 03-08-2011, 11:12 AM
Old School Heavy
speedtigger's Avatar
Are people breaking high quality 1/2" studs?
Old 03-09-2011, 01:16 AM
BlkBird2000's Avatar
I twisted the 1/2" studs that came on my moser 9" axles. I upgraded to APR 1/2" studs. Hoping these won't bend like the others. I personally do not want to go to 5/8".
Old 03-09-2011, 03:47 AM
Oldsmobility85's Avatar
Where did the lugnuts come from that will work with a 60° seat style wheel? I have a hard time getting my socket in the opening of my wheels with 12mm studs.
Quick Reply: Easy to go from 1/2" to 5/8" studs on the axles?
