Anyone on have a part number....
For a 9" Moser axle bearing and axle seal? My right seal is leaking and figured I should get it replaced. Car is 4ch if this makes any difference to the axles.
This is info I have I have not had a need to check it out
"FWIW, my axles/bearings were supplied by Moser, but the housing is a Quick Performance. Uses the same interal stuff as Moser, even the axles are the identical lengths etc..
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
I hope it is correct, Johnny
ps: from one of our great vendors (thanks Bob)
you can use regular axle seals. What I would do is to go to your local parts store, and tell them you need the seals for a 1975 Ford pick up with a nine inch. Same goes for bearings if you ever need them.
__________________
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
__________________
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
ps: I have been informed that the seal and bearing are the same as thoes used in the 1957 ford pu with 9"
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
__________________
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
__________________
You're welcome. Bob
