Which rear end for third gen??
Old 03-02-2010, 11:06 AM
Roachjr's Avatar
Default Which rear end for third gen??
Ok so I've got a 92 RS I'm puttin LS1 and t56 in. I want to get away from my drum, single track rear end. Are there any rear ends GM made from the factory that would handle an LS1 and have disc brakes for the third gens? I think I read some where that the rear ends that were put in the Iroc's were decent. Or should I not even waste my time and just buy a 9" moser with auburn, and 31 spline axles?
P.S., want to stay away from the fourth gen rear ends becuase I just recently bought new zr1's with the correct offset for the car.
Any suggestions would be appreciated! Thanks
Old 03-02-2010, 06:56 PM
Jon87transam's Avatar
you could try to find a 9bolt borg warner from the 80's. most have disk brakes, but were poor design. rears and parts for the 9bolt's are harder to find, plus they may have a differnent width than your current "1 tire fryer", but not the same as 4th gen either. don't think they were strong enough for what you want. you may have gotten your cart in front of your horse by getting the zr1's already. you may just want to do the 9" and have it finished. if your car didn't originally have the 9bolt, you may have the same thing we have with a 10bolt.
you could however just buy a powertraxx ratcheting locker for your current open diff until you figure out what you want.
Old 03-02-2010, 07:06 PM
kenSS's Avatar
you can find a dana 44 that were replacements in third gens or buy a 12 bolt, 9" or S60. I have an S60 with 93-97 rear disc brakes.
Old 03-03-2010, 06:29 AM
EPP
EPP's Avatar
You can order a Moser 9 inch with the correct width for your 3rd gen. You won't be able to reuse your stock brakes, 4th gen brakes are usually what people end up using. I would show you a link to this rear on my website, but the website will be down for approx one day.
Moser Rear End Prices At Exotic Performance Plus
Moser 12 Bolt with Eaton Posi for F Body, your choice of gear ratio
Torque arm mount
30 spline axles
$2,450.00 Free Shipping by UPS
Options:
33 Spline Axles with 10 year warranty $65.00
ABS (3 channel) or ABS/TCS (4 channel) $100.00
Exciter rings installed on axles for four channel option $75.00
Performance aluminum cover $135.00
Powdercoated, choice of colors $200.00
Lower control arm relocation brackets supplied and welded on $Free
Anti-roll bar brackets supplied and welded on for using BMR anti-roll bar $50.00
http://www.exoticperformanceplus.com....html?item=146
Moser 9 Inch with Trac-Loc or Locker (your choice) for F Body, your choice of gear ratio
Torque arm mount
28 or 31 Spline Axles For Trac-Loc, 28, 31 or 35 spline axles for Locker
Options:
Aluminum center section $155.00
Drain plug $35.00
Extra fill plug for easier access $35.00
ABS 3 channel option $175.00 N/A with alum center
ABS/TCS 4 channel option $100.00
Exciter rings supplied for 4 channel option $75.00
http://www.exoticperformanceplus.com....html?item=145
Moser 9 Inch with spool, your choice of gear ratio
Torque arm mount
$2,300.00 Free Shipping by UPS
Options:
Drain Plug $35.00
http://www.exoticperformanceplus.com....html?item=148
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,050.00 Free Shipping by UPS
Options:
Drain Plug $35.00
ABS 3 channel option $175.00 (Requires Moser center with optional 3 channel option)
http://www.exoticperformanceplus.com...html?item=1116
Moser M9 fabricated housing with axles and Trac-Loc in nodular iron center section $3,150.00 shipped
Includes chromoly torque arm and transmission crossmember
Same weight as 10 bolt!
Options:
Drain and Fill Plug (Free)
Many other options can be found here.
http://www.exoticperformanceplus.com...html?item=1324
I recommend the 9 inch rear for the higher horsepowered cars, and for those who have a manual transmission. Here is why.
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I feel the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Call us at 260 244-4808, or order the Moser rear of your choice from our website. Rear ends are ready to ship two days after order is received, allow added time if rear is to be powdercoated. Thanks! Bob
Old 03-03-2010, 08:23 AM
calebzman's Avatar
Unless you plan on taking the car to the track and using slicks, a stock 9 or 10 bolt thirdgen rear with posi, discs, and 3.42-4.10 ratio will work well with what you have. You should be able to find a nice used one for a few hundred.
Old 03-03-2010, 08:47 PM
Roachjr's Avatar
Thanks for all the input guys, I ended up going with a Moser 9" housing and 31 spline axles, Strange engineering center section with trutrac diff, 4.11's and 98-02 LS1 brakes. And powder coated black.
Quick Reply: Which rear end for third gen??
