traction controll ???
Old 02-25-2010, 05:16 PM
gregmelissalucky's Avatar
Default traction controll ???
on a 4th gen car is traction controll run through the abs system or dose the ecm pull out timeing thanks in advance greg
Old 02-26-2010, 08:50 PM
joecar's Avatar
The ABS controller detects wheel speed mis-match and asks the PCM to reduce engine torque which the PCM does by reducing ignition timing.
Old 02-27-2010, 01:15 AM
02CamaroSSLE's Avatar
and it feels like someone is pushing your foot back up... lol iunno if thats just me or somethin actually does that... lol and when you forget to turn asr off and go to spin your tires and it sounds like your broke something and you look like a jack ***
Old 02-27-2010, 01:31 AM
baalic's Avatar
I also think it individually controls your brakes too doesn't it?? I hydroplaned and my low trac light came on with my ASR on and it felt like it applied the brakes....
Old 02-27-2010, 05:23 PM
joecar's Avatar
There are 3 stages:
if EBCM determines that wheels are spinning, EBCM asks PCM to reduce engine torque and so PCM retards timing;
if EBCM determines that wheels are still spinning, EBCM asks ASM to reduce engine torque and so ASM asks ACA to close throttle angle (in F-car you feel throttle pedal pushing back);
if EBCM determines that wheels are still spinning, it applies either of rear brakes.
EBCM = electronic brake control module.
ASM = accelerator and servo control module.
ACA = accelerator control and adjuster.
Old 02-28-2010, 01:05 AM
Originally Posted by joecar
There are 3 stages:
awesome info man! thanks i have always wondered about that...
Old 02-28-2010, 03:05 PM
Checkmate's Avatar
is there anyway to remove traction control?
Old 02-28-2010, 07:31 PM
baalic's Avatar
Ya, turn it off... LOL
