gto rear end in 39 dodge
hi needing some help. trying to put a 06 gto irs under my fat fender roadster. need to know where to get a pinion flange to mount a 1 piece drive shaft. also does any one know what kind on rear gto,s have? mounting it seems fairly straight forward but having a problem with the drive shaft mount. thanks for your help in advance.
pinion flange
Looks like we are in the same boat. I'm looking for the same thing. Gforce1320 has a pinion flange but it is over $300. Nobody has answered my posts either.
The axle ratio on my 06 is 3.42. I think they are all the same.
Good luck.....Mine is going into a 52 ****** Aero Eagle...Had to build all the suspension (GTO stuff was too wide for my car) but am using the GTO hubs and brakes. Had to have shorter axles which I ordered from Gforce1320. Nice folks......
