98 trans am rearend? 7.5 0r 8.5? 10 bolt..
Old 03-09-2010, 09:55 PM
allan808's Avatar
Question 98 trans am rearend? 7.5 0r 8.5? 10 bolt..
im tryin to figure out what kinda 10 bolr rear i have on my 98 trans am...do i have a 7.5 or a 8.5? i wanna buy gears but cant find info on rear...thanks in advance!!
Old 03-09-2010, 10:03 PM
Slvr00Bird's Avatar
You'll need to know if your car has a 2 series or 3 series gear set though.. Know what gear came in it?
Old 03-09-2010, 10:14 PM
Johnnystock's Avatar
Originally Posted by Slvr00Bird
7.5..
How do you know its a 2 or 3 series???
Old 03-09-2010, 11:43 PM
01ssreda4's Avatar
Autos with 2.73 gear = 2 series
Autos with 3.23 gear = 3 series
M6 with 3.42 = 3 series
Old 03-10-2010, 01:48 AM
allan808's Avatar
i checked the RPO codes on the door and its GU2 so its 2.73 gears..so do i have a 7.5 rear?
Old 03-10-2010, 06:46 AM
bigj2717's Avatar
Yes they are all 7.5
Old 03-10-2010, 01:56 PM
thanks a lot for the clarification buddy! sorry for the hijack OP
Old 03-10-2010, 03:42 PM
supermouse4's Avatar
7.5" rear end.
Old 03-10-2010, 04:26 PM
allan808's Avatar
no worries!! so does anyone know where i can find some 3.42 or 3.73 for a 2 series carrier? i dont want to use a spacer but will if i have to..just tryin not to use it...thanks
Old 03-10-2010, 08:55 PM
Slvr00Bird's Avatar
http://www.jegs.com/i/Richmond-Gear/...oductId=744482
A lot of places sell them.. Not too hard to find..
http://www.speedinc.com/catagory.cfm.../%20Driveshaft
Old 03-10-2010, 11:03 PM
02CamaroSSLE's Avatar
is anyone going to advise him about putting gears in a 10 bolt??? no ok i will...
your rear is going to give if you drive it hard, may last longer than a m6 since your a A4 car but none the less, save you pennies for a 12 bolt or 9".
Old 03-10-2010, 11:35 PM
millersta's Avatar
i thought our rears were actually 7.625 but as 02camarossle stated our rears are a weak link i have an a4 and already blew my 3.73 i had and am back to my spare 3.42. if your looking for a better sotp feel i would just buy a used rear with a 3.42 or higher(numericaly) gear and keep your stock one as a spare. that is if you cant afford a 12bolt 9" or s60
Old 03-11-2010, 09:47 AM
01ssreda4's Avatar
My 10 bolt has been purring nicely even under heavy abuse. Just dont wheel hop
Old 03-11-2010, 10:12 AM
slp_z28's Avatar
I was going to say, it's actually 7.625". Not that .125" makes all that much of a difference.
Tips for not killing 10 bolts - don't shock them, or wheel hop too much.
Old 03-11-2010, 10:54 AM
Blackhawk777's Avatar
Keep wheel hop to a minimum, do the regular maitenance and get a girdle support and it should survive for quite a while with the auto. Just don't instantly hammer on it from a dead stop either. Once the car is moving a little, then you can jump on it. Mine has 125k on it and still whisper quiet.
Quick Reply: 98 trans am rearend? 7.5 0r 8.5? 10 bolt..
