Will I have to change the shift speeds/rpm in the pcm if I am adding 3.73 gears, or just the speedo calibration. Car has 3.23 gears with a 3500 torque converter now.
You will be fine, it just will get annoying. Mine will shift to early. But you can go from 3 - 4 and back. Get it changed when you have a full dyno tune.
It won't hurt anything, but until you get it tuned for the 3.73's your car will register more miles driven than it actually should (adds to the odometer quicker).
