traction and new gears
Im thinking about upgrading to 3.73 or 4.10/4.11. Will I smoke the tires any easier? Are these gears hell on the highway at traveling 65 or so?
i've had both 3.73's and now 4.11's w12bolt. the 3.73's are good and at 80mph i was on 1,900rpm's. the 4.11's are great with the m6 and at 70mph i'm on 1,800rpm's or so. with the 3.73's traction won't get much worse,but the 4.11's will fry the tires. the 4.11's will make the car feel 200lbs lighter. the 3.73's would be my choice if i did'nt have the $$$$ for a 12bolt. good luck to ya.
On street tires I haven't gone wot in 1st gear since my tune instant spin at any RPM, second gear is a little better but not much in stop light wars it's a bitch, now drag radials whole different story !!
That's going to depend on tire size. Assuming that your tires have 25.65 inches diameter (245/50/16's), here is the math -
tire circumference in feet = (25.65 * 3.14)/12 = 6.71 ft
rpm = (mph * final gear ratio * 88) / circumference in feet
rpm = (90 * 4.11 * 88) / 6.71 = 4851 rpm's
You'd be just under 5 grand at 90.
Now don't forget - 3rd gear in a th350 is 1:1, so you just enter in the rear gears as the final gear ratio. In an overdrive tranny, you'd have to know the last gear in the tranny (.73:1 for an example). Then final gear is .73 * rear end gear.
