2006 rear end
2006 rear end
is the rearend from a 2006 chevy silverado 1500 bigger than the stock under the 2002 camaro. I was wandering bc i got one for free from the wifes old truck and if it will work better than my stock one it under there this weekend!
Yes it is bigger, wider, has axles with six lugs, it does not bolt in the car, and it does not have a provision for the torque arm to bolt to. I'm not going to tell you that you won't make it work because nothing is impossible. But I can promise you that you won't simply bolt it in the car in one weekend and even if you did your wheels will not bolt back on.
