Which rear end rebuild kit to use when putting in 4.10's ???
Old 03-26-2010, 12:03 AM
Pro_built7's Avatar
Default Which rear end rebuild kit to use when putting in 4.10's ???
Guys,
Which Ratech rebuild kit do I need,
basic.. standard.. complete ??? (all have crush sleeve)
Basic has gaskets/pinion shims
standard has gaskets pinion shims/bolts/carrier shims.
complete has pinion bearings/all shims/gaskets.
I was just going to get the basic for $15 bucks and reuse my bearings is that ok... ?
Don't want to drop ANY more money into the 10 bolt than is absolutely needed lol. Buying a 12 bolt... eventually.
What do you guys think? thanks !
Old 03-26-2010, 06:57 AM
01ssreda4's Avatar
I always use 308tk
Old 03-26-2010, 08:47 AM
WizardofDetailing's Avatar
Stock rearend? How many miles are on it? Wouldn't hurt to change the bearings while you have it apart. But if it's a low mileage rearend, then you could probably get away witht he basic rebuild kit.
Old 03-26-2010, 10:43 AM
FirstYrLS1Z's Avatar
99 Z28,you probably got an auburn differential,but on the slim chance you have a torsen,you're gonna need a 'modified' paddle for use with 4.10s'.
Old 03-26-2010, 10:55 AM
01ssreda4's Avatar
all you have to do is grind the paddle a tad. No big deal. You dont need the $200 SLP paddle.
Old 03-26-2010, 11:04 AM
I agree,I wasn't implying to go and buy the 'expensive' paddle, just some slight modification to get it to work.
Old 03-28-2010, 01:25 AM
Pro_built7's Avatar
99 z28
unsure on diff ?
What is this paddle you guys speak of, never heard of that before I figure'd this would be a simple swap.
and the rear has 84k on it.
Old 03-28-2010, 01:26 AM
Pro_built7's Avatar
Its an M6 if that changes anything ?
Old 03-28-2010, 05:16 PM
Pro_built7's Avatar
sooo.... ?
Old 03-28-2010, 06:30 PM
Spartan7's Avatar
It's what presses the axles outward on a Torsen carrier. Similar to the cross pin in a clutch-type or open carrier.
I used the Ratech 3001k, because I wanted to replace all the bearings. If you're tearing into the rear end, you should anyway IMO. The bearings are good quality (Timken, Koyo, and Torrington, all made in USA and Japan).
The only thing about the kit I didn't like is the cover gasket. It's just cheap cork, so I spent an extra $4 on a Fel-Pro one.
Old 03-28-2010, 10:42 PM
Pro_built7's Avatar
Thanks!,
I'll probably just get the $40 kit then. I guess?
How do I know whether I have an auburn or torsen and these paddles?
Was also wondering where there is a swap guide?
Old 03-29-2010, 01:12 AM
millersta's Avatar
if you have an auburn you will see springs in the posi unit and a round pin if you have a torrsion there is the paddle thats been talked about
Old 03-29-2010, 09:50 PM
Pro_built7's Avatar
whoa wtf?
Is there any way to tell from outside the car ? any numbers/codes.. anything? don't want to end up screwed lol
Quick Reply: Which rear end rebuild kit to use when putting in 4.10's ???
