What is this piece? Broken?
Old 04-02-2010, 07:54 PM
MNBlade's Avatar
Default What is this piece? Broken?
I bought a Moser 12 bolt with Eaton Posi and 3.90 gears from a member on here and after sanding it down I saw this piece (in pic.) Im not sure what it is or what it does and after looking online for it for days I cant find pictures of it or what it should look like. Could it be a breather fitting or something thats broken? I plan on installing it within the next week.
Thanks.
Old 04-02-2010, 08:12 PM
bigj2717's Avatar
Its a vent
Old 04-02-2010, 08:33 PM
MNBlade's Avatar
Ok. Is it broken then? I don't have access to another Moser 12 to compare to. Anyone have any picture of what it's supposed to look like?
Old 04-03-2010, 02:05 AM
CW00BlackTA's Avatar
Yes it's broken. It should have a barbed end that sticks up a half inch or so with a breather hose attached. It's just a brass fitting you can pick up at a hardware store. Take that one with you.
Old 04-03-2010, 02:16 AM
CarsandWomen's Avatar
this, its the breather vent, put a one way check valve on it or a rubber hose with the other end high enough to not get water in it. every single axle has one, including your 10 bolt
Old 04-03-2010, 02:17 AM
ps that pic was taken 5 min ago, just for you, on my 33 spline Moser 12 bolt, easton posi, 4.10 gears so yes its the exact same thing youve got.
Old 04-03-2010, 12:18 PM
MNBlade's Avatar
Ok great! Thats what I was looking for. Thanks
