The 4.10
Old 01-05-2004, 04:50 PM
White2kTA's Avatar
Default The 4.10
I want to gear my car and call it good enough for my ls1's performance. As it is now I've done, lid, filter, FRA, maft, cat-back exhaust, and i want to do a 4.10. What all do i need to get that to work. Is it simply replacing a ring and pinion set? Where is the best place to go for gears and the propper stuff? Does anybody have any other ideas for cheap and easy to install performance?
Old 01-05-2004, 06:40 PM
Jorday's Avatar
If you have a 6 speed, I would recommend a set of 4.10 gears. I thought they were one of the best mods I did to my old M6 car. If you have an auto, you might look into an aftermarket torque converter instead of a gear swap.
btw...I bought an install kit for setting up the rear When I did my gear swap on my old car. I got the stuff to do it from thunder racing.
Old 01-06-2004, 06:08 AM
mcflyz28's Avatar
speedo calibrater unless you have edit.I have my old SLP processor if you need it make me an offer.
Old 01-06-2004, 09:24 PM
White2kTA's Avatar
you have to calibrate the speedo after you do a gear install? How is that done even? And approx what am I looking to get the right parts. What all was in the kit you bought Jorday? And mcfly what else can the calibrator do?
Old 01-06-2004, 10:20 PM
Jorday's Avatar
It came with gears, rearend cover, gasket, gear oil, marking compound, bearings, pinion shims, crush sleeve, pinion nut, stud kit, ring gear bolts. I think that's all if my memory serves me.
Old 01-07-2004, 07:16 PM
mcflyz28's Avatar
The calibrater does nothing but correct the electrical signal for the electronic tachs in these cars, if you don't plan on getting LS-1 edit or another programmer you need something to adjust your speedo or it will read high.
Old 01-08-2004, 11:57 AM
Tranzor's Avatar
Thunder Racing has a good gear swap kit, comes with everything you need... and IMO, it's worth it to spend the extra bucks for the Strange gears in their kit.
I'd go to their website and email or call them to talk about your individual setup...
www.thunderracing.com
