Moser 9" noise
Moser 9" noise
I have two f bodys with 9". One is a MWC FAB 9" and my new one is a moser ( the one i'm having a problem with )unit with alum case, tru trac 31 spline,4.11s new strange CM drive shaft. ALL new suspension for drag.
My problem is when on hard acceleration at 80+ i'm getting a low groan from the rear, gradually gets a little louder as speed in creases. It runs fine , virtualy no noise otherwise and havent had any problems with the rear at normal driving speeds.
This has me concerned with taking it to the track so far.
ANY suggestions???
ANY suggestions???
LS1Tech Sponsor
ANY suggestions???
ANY suggestions???
If you're absolutely certain that the torque arm bracket is not rubbing the floor, the next thing I would look into is making sure the pinion angle is set to around -2 degrees. I've seen this to be the cause of problems in the past, and it can throw you off. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
