Rearend just started making a weird noise 5 minutes ago
Old 04-16-2010, 12:12 PM
Slash8915's Avatar
Default Rearend just started making a weird noise 5 minutes ago
Ok, so I just drove to Walgreens, and everything was fine. Got back into my car, and I noticed a whistling sound coming from the rear. It sounds like when there's a small crack in your house window and the wind blows through it, like howling. But the thing is, I can be in park and just give it a little gas, and the sound gets louder with the RPM's.
Any idea what this is?
Old 04-16-2010, 12:27 PM
Greekey's Avatar
Your car is parked and your hearing a whistling noise?
Old 04-16-2010, 12:30 PM
cambirdracing's Avatar
Not the rear end if you are in park. Probably a vacuum leak.
Old 04-16-2010, 12:32 PM
Greekey's Avatar
Could be a exhaust leak. If your car is not moving, your rear end will not make sounds.
Old 04-16-2010, 12:35 PM
ROCNDAV's Avatar
Check that 45 degree rubber elbow between the TB and PCV valve.
It usually rips open on the bottom side where you cant see it, you'll have to feel for it.
Old 04-16-2010, 12:36 PM
Slash8915's Avatar
That's what I was thinking. It HAS to be an exhaust leak. Come to think of it, my elec. cutout stopped working the other day. It won't close anymore. I wonder if that has something to do with it.
Well, it's definitely coming from the rear of the car. It SOUNDS like it's coming RIGHT from the differential area, so that's what had me wondering.
Old 04-16-2010, 12:38 PM
getusumws6's Avatar
could be the fuel pump ....
Old 04-16-2010, 12:41 PM
Slash8915's Avatar
Hmm... just had the fuel pump replaced with a walbro about a year ago.
Old 04-16-2010, 12:43 PM
getusumws6's Avatar
Well my walbro's are noisy, just a thought
Old 04-16-2010, 12:44 PM
Slash8915's Avatar
I've heard that too, but it never made a sound until now, almost a year later.
Quick Reply: Rearend just started making a weird noise 5 minutes ago
