moser 12 bolt through bolts?
Old 04-25-2010, 07:10 AM
greatskiiiier's Avatar
Default moser 12 bolt through bolts?
is it possible to drill through the moser 12 bolt and put through bolts on the torque arm? my top bolts came out and forced me to rent a u-haul from the track
stripped the threads on top of the axle and bent the bracket...i have the tooling to do any machine work ill need to get this problem SOLVED
Old 04-26-2010, 02:50 AM
Black 99 Bird's Avatar
I don't think you can drill all the way through. Need to google "safety wire". This is an easy fix.
Old 04-26-2010, 04:18 AM
2002gt's Avatar
Mine also came loose.
I drilled the bolts for safety cable. I used locktight and used lock washers under bolts. With the 3 locking features, I never had a bolt loosen on my 12 bolt.
Old 04-26-2010, 04:53 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Safety wire is the best way to make sure the bolts don't loosen back up. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 04-26-2010, 07:26 PM
Bill00Formula's Avatar
Doesn't drilling the bolts weaken the bolt head so that it may break when you tighten it or loosen it?
Old 04-27-2010, 01:05 AM
2002gt's Avatar
You just need a small hole that is chamfered on each end for the wire. I work at a aircraft engine manufacturer and every external bolt & nut is safety cabled. Never heard of the bolt breaking.
2002gt
Old 04-27-2010, 01:09 AM
2002gt's Avatar
Here a example link.
http://www.byrongliding.com/lockwire.htm
Old 04-27-2010, 07:27 PM
thanks for the information. I'll do this when I put my 12 bolt back in.
