12 bolt IRS for the 2010 Camaro. Prototype Done.
It is finally here! The ultimate 12 bolt irs for your 2010 camaro. This IRS center section will bolt up in place on your existing mounts. This unit will require a new rear driveshaft to accomodate the 1350 joint and new half shafts. Which you will need anyway if you are running the horsepower that requires this centersection! We are working with Moser as the supplier of the stubs and half shafts which should be available shortly. This makes 35 spline WaveTrack lockers, 40 Spline spools, Pro gears and all the gearing for a 12 bolt available for your 2010 Camaro!
Please contact Fred "Skip" Lee at ET Enterprises for ording and pricing information! 231-740-5534.
