need help ASAP third gen drive shaft in 4th u joints
Old 04-29-2010, 08:37 AM
johny's Avatar
Exclamation need help ASAP third gen drive shaft in 4th u joints
hey guys im running a 3rd gen aluminum drive shaft in a 97 WS6. when i first installed the shaft i notice the u joints where to small and had allot of play when i tighten the bolts to the axle. so i just took off the caps that came with it and installed the caps from my factory steel drive shaft and it bolted up. i was having some weird noise/vibration when accelerating from a stop. then it goes away as i pick up more speed. took it to school and my teacher said that its unsafe and to use the proper u joint or the car could flip over. im doing a 800 mile trip tomorrow so please anyone know the proper u joint or at least a part number? i went to the parts store and had no luck. thanks for the help guys.
Old 04-29-2010, 02:37 PM
99ssleeper's Avatar
most likely it is a 1310 to 3R conversion joint. the 4th gens take a 3R u joint, the 3rd gen may be a 1310 but im not sure about the 1LE d/s if thats different from a non-1LE.
i THINK 93-97 4th gen 1LEs got 1310 ujoints which might be a carry over from the 3rd gens, but i cant say for sure.
this may be what you need:
http://www.dennysdriveshaft.com/p498...reaseable.html
Old 05-03-2010, 02:10 PM
johny's Avatar
thanks a billion. its on it way.
Old 05-06-2010, 11:06 AM
99ssleeper's Avatar
i hope it works out for you. im just making an educated guess. they do list the ujoint cap sizing.
Old 05-23-2010, 03:47 AM
johny's Avatar
put it on and it works perfect. no vibration at all.
Quick Reply: need help ASAP third gen drive shaft in 4th u joints
