PST Driveshaft question
Old 04-29-2010, 09:04 AM
rabiddog's Avatar
Default PST Driveshaft question
I went searching throught a few pages of post and haven't found anything on driveshafts. I shattered mine at the track last night and am thinking of putting a 3.5" PST aluminum driveshaft in its place. I am only pushing 410RWHP so I am thinking it should work.
Is this a good buy for 400 bucks or is there another driveshaft I can live with that is cheaper.
I am going to be putting it on a 10 bolt so I am guessing I will be getting a 9" soon since first to go was clutch, then tranny, now driveshaft, next rearend.
Old 04-29-2010, 10:44 AM
chino_man279's Avatar
No problems at all with my PST shaft. Perfect balance, very beefy. It is a lot lighter than I thought it would be considering the size of it.
Old 04-30-2010, 07:13 PM
LS1-IROC's Avatar
Check your local drivetrain shops...you usually can have one made for cheaper than the mail order guys.
Old 05-01-2010, 01:17 AM
BriancWS6's Avatar
My PST drive shaft has been good so far as well. Nice piece.
Old 05-01-2010, 11:45 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I recommend the PST 3.5 inch alum driveshaft. It handled all the abuse we put my Camaro through, including a televised wheelstand competition where the car went up on the parachute mount, and all four tires were off the ground. I am currently selling these PST driveshafts at $400.00 shipped. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-01-2010, 01:48 PM
quik01ss's Avatar
Get the pst and don't look back I got one when I put the S60 in it was exactly 1 lb. Heavier than the stock aluminum driveshaft although the pst is shortened 1.622 inches
Old 05-10-2010, 11:47 AM
minytrker's Avatar
My PST 3.5 inch alum driveshaft lasted 3 launches before it broke and took out my transmission, exhaust, rear end, and parking brake. I went to a DOM steel one made locally for less $ and havent had any problems (+50 passes).
Old 05-10-2010, 11:58 AM
LS1Tech Sponsor
Question
Something just doesn't sound right, are you making well over 1000 hp? I have never had any problems with the PST Driveshafts I have used, including the one shown here. Bob
__________________
Old 05-10-2010, 01:02 PM
LS1Tech Premium Sponsor
MidwestChassis's Avatar
We sell a decent amount of PST drive shafts and have had all good reports on them so far. If you have any questions please PM me for info and pricing.
Old 05-13-2010, 08:04 PM
minytrker's Avatar
No, under a 1,000 but l leave on alot of nitrous. At the time the car was full weight with a really good 4l60e, it did 60 really well. I broke the stock driveshaft, replaced everything, trans included, installed the pst and lasted 3 launches. I then had a real driveshaft made, same suspension, everything else the same and 3 years later almost and never had another problem. So I dont think its the car. PST was even shocked on how it broke, they wouldnt give me a refund but they did send me another driveshaft, I didnt even open the box, I sold it.
Old 05-14-2010, 06:27 AM
LS1Tech Sponsor
That is bizarre, and is the first one I have heard of. Bob
__________________
Old 05-14-2010, 03:00 PM
ssvert99's Avatar
we haven't had any issues whatsoever with the PST shafts, either. keep in mind, PST nor any other manufacturer does not manufacture the tubing so there is always a chance any shaft can fail if there is a bad spot, though not likely.
I have personally seen many of the exhaust setups on f-bodys have contact with the driveshaft when the rearend is hanging(car on jackstands, hoist, etc). any sort of contact(especially while rotating) with any component can compromise the integrity of any driveshaft, and its up to the installer to make sure the shaft is installed correctly and has proper clearances. this particular guy with a PST shaft failure could have had this happen and never even known about it. then once high enough torque is put on it and you have a failure. all i'm saying is that even the most expensive, highest quality parts can fail if not properly installed or maintained.
Old 05-15-2010, 06:38 PM
Leedogg's Avatar
I ordered a steel PST with my MCW rear- was skeered of the aluminum.
Old 05-17-2010, 09:51 PM
LILWS6's Avatar
i'm waiting on my pst to be built and shipped still have to assemble my 12 bolt as well
Quick Reply: PST Driveshaft question
