Stock Rearend?
Old 05-01-2010, 02:37 AM
Pythias's Avatar
Default Stock Rearend?
Well I looked at the sticky and obviously I have a 10-bolt but what comes stock in my 2002 Trans am a 7.5 or a 7.6 rearend?
Old 05-01-2010, 06:46 AM
FirstYrLS1Z's Avatar
7.625-7 5/8. All internal parts are interchangeable between 7.5/7.6(7.625 and 7 5/8 are called 7.6) EXCEPT for 7.5 carriers that are for 26 spline axles,but parts for 26 spline carriers,such as carrier bearings,gearset,pinion bearings are interchangeable with the 7.6 rearends.
Old 05-01-2010, 12:14 PM
Pythias's Avatar
So when ordering a master rebuild kit for the rear end and gears is there anything I need to look for specifically? I'm planning on ordering this kit.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
I'm not trying to advertise here either, simply trying to make sure I'm buying the right thing. This is for a rebuild on my stock 02 trans am 6sp.
Thanks
Old 05-01-2010, 12:52 PM
what you linked is not a rebuild kit but a gearset and it is not for your 6 speed car which has a 3 series carrier because it has/had 3.42s'. the link is for a 2 series gearset.
Old 05-01-2010, 01:05 PM
Pythias's Avatar
This is the rebuild kit I meant to post, this will work for my rearend correct?
And this gear kit from summit will work?
http://www.summitracing.com/parts/SUM-741013/
I'm just looking for stock gear replacements at the lowest price.
Old 05-01-2010, 04:26 PM
Yes and Yes.
potential problem is going to be the pinion seal. there are 2 styles/sizes and you really don't know which you have until you take it apart. it's a not often occurring problem on 00-02 f-bods. your local parts stores typically stock both so you can take it with you to match it.
you didn't mention anything about axle bearings and seals,since you're doing a complete teardown.
Old 05-01-2010, 05:26 PM
Pythias's Avatar
Originally Posted by FirstYrLS1Z
Yes and Yes.
I've never had a rearend rebuilt so I didn't know I needed to do the axle bearings and seals. They aren't included with that kit I posted?
Old 05-01-2010, 06:44 PM
fleetmgr's Avatar
no, it won't come the axle bearings/seals.
Old 05-01-2010, 07:36 PM
Pythias's Avatar
http://cgi.ebay.com/ebaymotors/YUKON...Q5fAccessories
That appears to be the full rebuild for my rear end plus axle bearings correct?
Old 05-01-2010, 07:43 PM
NO,it doesn't contain axle 'stuff'. Rearend rebuild 'kits' don't contain axle brngs & seals.The 'better' GM rearends of 8.2,8.5, & 8.8,axle bearings and seals are on the axles,not in the housing as in our puny rears.
Old 05-01-2010, 10:53 PM
fleetmgr's Avatar
Nope. That kit has pinion bearings and seal, plus the pinion shims and a new crush sleeve, and the carrier bearings - no axle stuff at all.
Old 05-02-2010, 04:27 AM
Pythias's Avatar
ok so the local autozone should have this stuff? I;m going to call tomorrow as I cannot find it on ebay.
Old 05-02-2010, 05:51 AM
http://www.autozone.com/autozone/cat...roductId=12123
http://www.autozone.com/autozone/cat...&parentId=12-0
