breaking in rear
Old 05-06-2010, 10:23 AM
nexstar7's Avatar
Default breaking in rear
im having my diff purged. when they put the fluids back with the additives, whats the proper way of breaking it in. also im getting a dyno tune, should i do the tune first or fluids first depending if there a break in period for the fluids. thanks Ralph
Old 05-06-2010, 11:02 AM
GMMillwright's Avatar
Not to hijack the OP, but I'm in the same boat. Just getting ready to start driving on my new Midwest FAB9 with Detroit Locker.
Do I need to run a special "break-in" fluid? If so, for how many miles? Once that's done is it OK to run synthetic with the locker?
Thanks.
Old 05-06-2010, 11:51 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
we don't suggest the use of any synthetic fluids for the first 500 miles. as far as a new gear break-in, you need to do 5 heat cycles with no abuse. this is light street driving, don't go over 55mph, don't go down the highway for 20 miles at 65mph. just drive it like a grandma on sunday . no clutch dumps, burnouts, full throttle accel, etc. about 15 minutes at a time, then let it cool off for no less than 1 hour between cycles. a heat cycle is from cool to full operating temp, them back to cool. this needs to be done 5 times.
the purpose of this is to surface temper the gears. all gears are heat treated, but it is essential for the life of the gear(and incidentally noise level) to break-in the gear properly and this process of bringing the gears up to temp slowly and letting them cool slowly is what does the job. Richmond Gear told me that 95% of all warranty claims they see are from people either not doing the break-in or improper method.
Old 05-06-2010, 12:33 PM
Thanks for the quick reply, Eric. Do you recommend synthetic after break-in? What viscocity? 99% street driven, BTW.
Old 05-06-2010, 12:36 PM
02sleeperz28's Avatar
Thanks for this thread I need to break in my new rear also.
Old 05-06-2010, 12:37 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Define "having my diff purged." I'm assuming you are talking about a new ring and pinion and bearings since you are asking about break-in, but it isn't clear what you mean.
Old 05-06-2010, 01:10 PM
ssvert99's Avatar
synthetic can be used after break-in yes, but some diff unit manufacturers do not recommend using synthetic oils. as far as viscosity, for the break-in just any GL-5 rated or better 80/90 is fine. after the 500 mile if you do alot of highway driving or roadcourse use maybe a 85-140 type would be good. drag only cars could get away with a thinner racing type lube. any of our clutch type posi units will require a additive and we recommend the Ford OEM Friction Modifier. the Wavetrac, Truetrac, Detroit Locker, and spools do not require additives.
Old 05-06-2010, 01:50 PM
getusumws6's Avatar
I think the OP is just having the fluid changed, in that case you dont break-in fluid.
Old 05-06-2010, 03:49 PM
nexstar7's Avatar
just draining the fluids and adding new fluids
Old 05-06-2010, 03:51 PM
nexstar7's Avatar
thanks getusumws6
Old 05-06-2010, 10:28 PM
MeentSS02's Avatar
As stated...no break-in required for fluid changes only.
Old 05-08-2010, 08:29 PM
alamantia's Avatar
Just break it on the same way you did it whwn you bought the car.
Old 05-09-2010, 10:24 AM
slvrbackls1's Avatar
Do you mean the wacetrac and truetrac need the additives and the locker and spool dont. Im confused??
Old 05-21-2010, 05:12 PM
MidwestChassis's Avatar
They do not, a clutch posi is the only ones that require an additive.
