a4 gear question ASAP !
I have a 4l60e with a yank 4000 will be running a 28" tall tire. Spraying a 125 shot and i have a 233/239 cam l92's ls3 manifold should i get a 3.73 gear or a 3.90 or what?
I haven't installed everything yet to test out the combo but after looking at some gearing calculators I went with 3.90's for mine.
4l60e/ SS3800/ 28" tire/ 150-200shot/ tfs235's
with the 28" tire I wanted the extra gear, if i was staying 26" i would have just gone with 3.73s
last year with 10 bolt/3.73/25.5 tire trapping 124.5
Johnny
I went 10.50 at 130mph, with a 4400 converter and gobs of NOS. I would make sure you can lock up the converter in drive (3rd gear), and run a 4.10 gear. Then converter effiecency isnt a factor. 3.90s will be fine too. If you stick with slicks, a 4.10, if you run radials then a 3.90. Hope that helps!
