pinion gear ???
pinion gear ???
Need some help I'm replacing my pinion bearings and seal and I've got everything out beside the pinion and the thing won't move. I thought they were suppose to come out fairly easy ? Any advice or maybe something I forgot to do?
The bearing behind the pinion yoke was a pretty tight interference fit for me. Getting it off I had to pound the pinion out with a hammer. I had to use an impact wrench on the nut while holding the yoke to press the new one on.
I think the dealer has a special tool to pull that bearing off once the nut & yoke are off.
Just tap the pinion out with a hammer but be sure to put an old nut on the pinion or use a punch. That pinion seal bearing is a tight fit if you just install the gears right out of the box. The best thing to do to avoid this problem in the future is get some 180 grit sand paper and sand off the gear coating on that portion of the pinion. You will never have this problem again.
outlaw that is exactly what i did lol tried the whole rubber mallet thing didn't work and then the light bulb came on and tried it with the old nut and hammer worked like a charm!!
The gear set was already bad but I had a booger one time. A few taps with a hammer, no bueno. I pulled out big bertha and smacked it right on the threads, the pinion went flying across the shop....LoL
