LT1 ---> LS1 3 channel or vice versa?
Old 05-25-2010, 10:29 AM
DopdBrd's Avatar
Default LT1 ---> LS1 3 channel or vice versa?
Will a 3 channel S60 from a LT1 fit into a 3 channel LS1 car? And will a 10bolt from a 3 channel LS1 fit into a 3 channel LT1 car? What needs to be changed? Thanks guys
Old 05-25-2010, 06:03 PM
kkslds's Avatar
I believe the only difference is the brake setup. As far as the 3 channel abs system itself, its all the same. I have a buddy who put a 3 channel rearend from a lt1 in his 01 z28 with lt1 brakes and all, and has been running for years without problems.
Old 05-28-2010, 01:08 PM
Gabbiani's Avatar
Backing plates and brakes are the only real difference.
The diameter of the rotor hat on the axles was a tiny tiny bit different. Not enough to matter.
Swapped my 4.10 lt1 rear with a 3.42 ls1 rear - gear upgrade for both of us.
Quick Reply: LT1 ---> LS1 3 channel or vice versa?
