Has any one tried removing the tq arm and installing an upper center control arm?
Old 06-02-2010, 06:30 PM
FireChickenws6's Avatar
Default Has any one tried removing the tq arm and installing an upper center control arm?
I tried searching with no luck. I was wondering the other day how I was going to try to run true duals and then Light bulb!! I would have a lot more room with out the torque arm in the way. Yes it is a durr situation.
I'm wondering if it would be possible to install a center upper control arm and delete the torque arm?
Then run the exhaust on both sides of the drive shaft and be able to tuck it up a little more for clearance?
Any ideas, advice or the link to the thread that already discusses this that I couldn't find would help. Thanks.
Old 06-02-2010, 08:18 PM
1BAD01TA's Avatar
this is from a company that when under a few years back, it a mustang 3 link convesion kit. a friend of mine and myself played around with this idea for 8.8 swaps, much safer (imho) that the welded on torque arms.
Uploaded with ImageShack.us
Old 06-02-2010, 11:53 PM
sjsingle1's Avatar
watts link???
Old 06-05-2010, 04:34 PM
Watts link is for deleting the panhard bar and keeping the rear end centered during changes in vehicle height.
1BAD01TA - That could work but it looks a little more complicated. I was thinking more along the lines of just 2 brackets and a center link.
So no body has ever thought about or tried it?
Old 06-06-2010, 12:11 PM
96lt1m6's Avatar
8.8 build
https://ls1tech.com/forums/gears-axl...8-8-build.html
