anyone has experience with G9 Diamond Trac-III or DPI's Black Gold Diffs for 8.8"/9"?
Hi,
I'm looking for a beefed-up rear-end that can handle well in turns (don't care about straight line performance as much as cornering)... so 12-bolts are out of the picture since no good enough diff for my needs. I'll be outputting around 450 rwhp NA... and I might need to look into this maybe sooner than expected... so I'm doing the search now before it's too late.
Yet, the 8.8" and 9" seem to offer better solutions.
Anyone has experience with one of the following diffs?
I presently have a Torsen T2R in my 10-bolt.
I know they make them for 8.8", but don't seem to make them for the 9".
I'm still woundering which route would be better... 8.8" or 9" for my needs. and trying to look at all feasible possibilities.
These designs seem to be very similar to the T2R which I enjoy a lot when RoadRacing and/or AutoX-ing... cause I can floor the car coming out of the curve, without having the inside wheel spin... so was just woundering for your feedback.
I also heard of a place in TX that make 8.8" for the f-bodies... I think they are called ExtremeChassis.
Thanks,
- G9 Diamond Trac-III
- DPI's Black Gold Differential ?
Thanks,
Seems like your pretty much on your own on this one flying solo. I am very interested to see what you can come up with that works well. I have several sessions that I was planning to attend at Road America and Gateway and a few other tracks. So if your setup works I deffinatly plan to copy it. LoL. Sorry man. Seems like not alot of people are into Road racing.
LSX Mechanic
If you aren't concerned with straight line/drag strip performance, you're wasting your money on an aftermarket rear end. The stock 10 bolt will be just fine for road racing. More times than not, stock 10 bolts are broken while running on slicks launching hard. Since that is not your concern, why waste the money on a drag racing rear end?
josh
josh
It's just that I drag once in awhile and with around 450 NA RWHP ain't too bad until I decide to spray the 250+ DP nitrous.
So, I'm budgetting for a rear just in case.
Thanks for the replies... so far I hit a dead-end here and at www.ls1.com
Made a similar thread... but looks like SOM WS6 is right
Maybe it's just... j/k
LSX Mechanic
josh
My 10 bolt might make it through the end of the year if I don't beat the **** out of it at anymore track sessions. But once that x3 goes in around July I don't expect it to live very long.
Originally Posted by Damian
Well all I can say is you definately do not want to run the 9 inch. They are heavy, and will GREATLY decrease cornering ability. I would look into the 8.8 since it's only about 15 lbs heavier than a 10 bolt..
josh
josh
The 9" can be made very good for turning, provided you have an excellent diff... it's just that most people buying those will get locked diffs.. and those are $h!t for cornering.
LG once posted that one could get a 9" for pretty much the same weight as a 10-bolt... I think I'll be giving them a call sometime this spring.
