please help
Old 06-15-2010, 08:10 PM
SS-Power's Avatar
Default please help
I started hearing a thumping sound in the rear whenever I hit poholes. The sound reminds me of a bad strut mount or a bad shock. So i jacked the rear up and started pulling on the rear tire to make the noise again. There is some play in the tire and also there is a clunking sound. Could it be bad bearings or something else. This noise has been driving me nuts. Any thoughts????
Old 06-16-2010, 08:20 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I've seen stock torque arms bend approx 6 inches ahead of the rear, and cause the front of the rear end to angle up so high the springs almost fall out of their pockets. You'll just have to check everything out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 06-18-2010, 12:35 AM
Outlaw72's Avatar
The play you have in the tire should be the axle moving back and forth hitting the center pin in your carrier. It's normal but not likely your culprit.
Old 06-18-2010, 05:50 PM
SS-Power's Avatar
I will check that out, thanks
Old 06-18-2010, 05:52 PM
SS-Power's Avatar
ok, thanks. I will keep looking and try to find the problem.
