press ring for a 12 bolt
Like the title says I need a press ring for a moser 12 bolt with 35 spline axles. Im having the bearings pressed off then on so I can put my backing plates on. I have to destroy the press ring to get the bearings off. Im looking for a place I can get new press rings. Any help will be greatly appreciated
Talk to Bob @ BruteSpeed.....you might have to get a new set from Moser. Unless you can get them from an auto parts store. Unfortunately, they all have to be destroyed when the come off. 2 or 3 pops from a big ol' hammer and they crack right off.
Sounds like you dont have your backing plates on there now? FWIW I could not save my old bearings as I could not get the bearing seperator in there with the backing plate and hub in the way. I'm pretty sure the press rings are available when you buy a new bearing. hth
LS1Tech Premium Sponsor
we have the bearings, press rings, or whatever you need in stock. we will need to know what axle shaft diameter you have as there are a few different ones used. this can be easily measured on the shaft where the press ring rides with a caliper or mic. call us if you want to order.
