Gear Oil Change - yes I searched
Okay from the search I did I found that people either use 75w90 or 75w140. What brand is normally used and what do people use to get the oil into the rear?
I have a 2002 Camaro Z28 6 speed with 3.42's. I'm pretty sure this is the torsen unit, so that means I don't need the limited slip additive...correct?
torsen=no additive required.
75/90 is whats recommended so thats what I have always run. Brand is preference, I personally dont think it really matters.
I'll be doing this in about two days thanks for making thread JohnnyBz28 it was really helpful for me (POS stock 10 bolt immediately crapped on me when i was running DR's). now how do i know if i have a torsen vs a limited slip diff??? (Can't you tell jus by taking off diff cover and looking?) and if i have a limited slip diff what additive is needed. Thx..
I believe the Auburn has yellow on the gears.
A torsen:
I use a "shampoo pump" you can get from a beauty store or sometimes walmart, etc. Drop it right into the jug of gear lube and pump it in.
Who knew you could get stuff for working on cars at a beauty store! LOL!
