How do I change the wheel studs on a 3 channel 10 bolt?
Old 06-27-2010, 03:03 PM
Tommyv8's Avatar
Default How do I change the wheel studs on a 3 channel 10 bolt?
Not sure which forum this belongs in so I'm posting it in here and in Wheels and Tires.
I have a 3 channel, so there's no hole in the backing plate where the TCS sensor would be. Do I have to pull out the axles or drill big holes through the backing plates to put longer studs in the back? I think I remember seeing a thread where someone managed to do it without having to do either one of those things but I could be wrong; I couldn't find the thread. Thanks.
Old 06-27-2010, 03:25 PM
Egg1456's Avatar
there should be a hole that the studs will fit through and u can just hit them out the back of it. if not just pull the axle
Old 06-27-2010, 04:58 PM
Tommyv8's Avatar
I guess I have to pull the axles.
Old 06-27-2010, 05:11 PM
coldblooded's Avatar
This should help
https://ls1tech.com/forums/wheels-ti...r-ts-more.html
Old 06-27-2010, 08:52 PM
Tommyv8's Avatar
Originally Posted by coldblooded
I'm looking at those pics and at my rear end and they don't look the same to me. Did he somehow remove the parking brake when he did that?
