Hit a brick wall during 12-bolt swap
Old 07-14-2010, 11:58 AM
W es 6's Avatar
Default Hit a brick wall during 12-bolt swap
Background: I bought a fully-assembled Moser 12-bolt, and opted to reuse my stock backing plates. As you all know, this means that I have to remove the backing plates from my stock rear, slide them onto my new axles, and then press my axle bearings onto the axle.
Problem: When I received the rear end, the axle bearings were ALREADY pressed onto the axles. After driving to 3 separate machine shops, I was told that there is NO way to remove the bearings and salvage them. That means that, unless I can find an alternative, I'm going to have the brand new bearings removed from my brand new axles, and then shell out for a pair of brand newer-new axle bearings!
I already have a call into Moser, and they are looking into the problem as we speak. Does anybody have any other ideas?
Old 07-14-2010, 12:51 PM
W es 6's Avatar
Problem solved... Moser acknowledged their screw-up and is over-nighting a new set of axle bearings at no charge A total of 2 phone calls (5 mins each) and the problem is fixed. Great customer service, Moser!!!
Old 07-14-2010, 01:36 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yup, UNLESS you send them Backing Plates They should not be sending you axles with the bearings pressed in.
BUT I will say I have had a shop remove my bearings due to a LT1 to LS1 Moser Swap and I brough them the axles. With a generic press they came out with out, put the LS1 back plates on and I slugged her in and no issues since.
Old 07-14-2010, 04:36 PM
Jawsgear's Avatar
Glad to hear it.
Old 07-18-2011, 01:25 PM
KRAZY K 2000 TA's Avatar
what was there part number for the axle bearings mine are wasted?
Old 07-18-2011, 01:31 PM
Anniversary "Z"'s Avatar
And some say it's not worth the extra $$ to buy from a brand name...
Glad to hear Moser rectified to problem for you!!
Old 07-19-2011, 06:17 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
- Napa Replacement part numbers for 12 bolt wheel bearings: Bearing: 9508b
Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 07-20-2011, 07:27 PM
Valkyn's Avatar
I put my the backing plates on the wrong axles on my moser 9" and easily removed them with a press.
When I reinstalled them it felt like they pressed on just as tight as they did originally so I dont see why you cant reuse them.
