Trutrack gone bad
Trutrack gone bad
Ok, so last year I went out and bought a Moser 9inch with the trutrack posi thinking I'd be ok. After a visit to the track in may, the rear would make a clicking noise whenever I make a hard right turn. I decided to tear into the rear this past weekend and have the center section out of the car. Nothing looks broken. Is there any guide on how to take the trutrack posi apart? Should I just send it to Moser? Any input would be greatly appreciated.
i bet the planetary (sp) are missing a couple pieces. the top four out of mine were missing chunks and the bottom four all had grooves worn around them.
you dont need a guide to take it apart. i had mine apart in 5 minutes. it easy.
Internet Mechanic
Tru Craps are sealed units, not intended at all to be rebuildable. Also the the splines are uniquely cut so when I decide to do a spool these will be junk and at the same time I will be narrowing the rear. That will be fun.
Mine basically locked like a Spool so all I get is excessive then the average tire wear.
Mine dose, and still dose look fine inside. Its drove fine obn the street making no noise, I run it again in a street car with no slicks for sure.
I just bought a spool and put my ring gear on, new bearings in the spool in put it in. that was it.
https://ls1tech.com/forums/drag-raci...light=truecrap
I have one in my S60 and I'm swapping to a Detroit Locker, I also have an OBX racing LSD in my 2000 Z24 turbo Cavalier and I took it apart, deburred all the gears, cleaned it and replaced the weak stock preload washers with stronger ones and put it back together. I haven't had any problems with it but on a heavy high whp/wtq car on sticky tires I'd use a locker or spool. When I brought my S60 the info sheet indicated that the trutrac was good to 600 rwhp.
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Yes it still can, and be causing the clicking problem. Bob
__________________
What is your suggestion then? Should I replace the axle and see if the problem goes away? I'd hate to buy a new axle then find out its the posi, because I'd like to get away from 31 spline axles if I upgrade the posi unit. How long can the posi unit last like it is in the current state?
LS1Tech Sponsor
Correct! Bob
__________________
