help with options for rear end
Alright well my rear end is on its last leg. I'm thinking about buying a new rear end. But id ont exactly know what options to get. It's a Moser 9" complete rear end assembly. It comes built to order.
Custom width a pinion offset? (Do I need to fill this out if i want it just like stock)
Spline count: 28, 31, 33 (spool only) (dumb question, what's a spool?), 35, 40 (spool only)
Stud type: a bunch of choices but I just want something that will fit stock wheels.
Brake manufacturer and model? (If I'm keeping stock brakes do I need to fill this out?)
4 channel ABS (47 tooth) is what I want for an 01 with tcs right?
Do I get fill and drain plugs installed for $70? Back brace installed for $140?
If you guys could please help me get the right stuff I would greatly appreciate it.
LS1Tech Sponsor
Check out this link, my prices include free shipping. http://shop.brutespeed.com/Moser-9-I...c-Truetrac.htm
No, and I don't offer it as an option on the late model F Body rears.
31 is what I would go with, along with the Trac-loc differential.
12mm short is what you need.
Nope, on my rears they are automatically set up for stock brakes, unless someone tells me they're using something else.
Correct, if you have traction control you will want the 4 channel, and you have an option to either reuse your stock exciter rings or go with new ones.
A fill plug is automatically included, the optional fill plug is easier to get to but is not necessary. A drain plug is a good idea in my opinion, in case you ever want to drain the rear it is much easier with a drain plug. Without a drain plug you'll have to pull the third member out.
A back brace on a Moser 9 inch is not needed unless you plan on running deep into the 8's in the 1/4 mile.
You mentioned what is a spool? I have a link below that explains what a spool is, along with a lot of other information. Bob
https://www.brutespeed.com/rear_end_information.htm
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
lol, that's a good price for a used one. Bob
__________________
