8.8 diff
8.8 diff
Ok so the 8.8 isn't in a f-body its in my winter beater, a 98 expedition. The spyder gears came apart and has chipped the pinion gear on one tooth. My question is what parts, if any are interchangeable with a mustang diff? And what years should i look for? Also looking for oppinions on how the diff would
hold up with the damaged pinion? I'm trying to keep it as cheap as possible, or do i just spen the money and fix it right. Thanks for any help I can get.
Well depends on spline but most all parts should work as long as the splines match. i would replace all the componets if it was mine. other used componets have different wear patterns. JMO
