pst ds question
pst ds question
Is there any advantage from one to the other? I didn't see anything about how much each one weighs. I was going to get the chromoly one but I'll never make over a 1000 hp. 800 MAX.
This is the only question I haven't annoyed Bob with, lol. I was just wondering if there was a weight difference between the two? The chromoly one is only 30 bucks more so I was going to go with it. Then again I was thinking about going with just the aluminum one cause it's nice looking. Polished vs black. ha
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Kleeborp the Moderator™
Depends on which one you get I'd assume...I think the aluminum version mentioned above is 3.5", so that is 0.5" larger in diameter than the stock DS (it is 3"). I would guess their steel offering is 3", but don't know for sure. I have a 3.75" DS, and don't have any clearance issues to speak of, and I was even able to get a safety loop to fit.
LS1Tech Sponsor
The PST 3.5" aluminum driveshaft is only .25 larger on any given side. Driveshaft safety loops and exhaust normally clear without any problems. Bob
__________________
yea i had an issue with the UMI loop, they have the loop about an inch too high! I had to shim the crossmember down (closer to the ground ) about 1/2" to clear the pst 3.5" shaft. Everything went on at the same time, it wouldn't have cleared the stock shaft either I don't think and my car is SLAMMED. That was with the stock T56. When I put the TH400 in I just shimmed the trans mount up another 1/4" or so for clearance and removed my TA mount shims, along with doing a 3" CM shaft. haven't measured the driveline angle yet...
safety loop was the least of my concerns with the PST. mine seemed just a little too long for my Moser 9 inch, about 1/2" too long, but it worked. my car is also a cam only car, making 412rwhp, but managed to twist the splines on the slip yoke. guy at PST was cool about it & sent me a new one ASAP. now just a couple weeks ago i thought i had a bad u-joint. once i got the driveshaft off the car & was able to push one of the caps through the driveshaft fairly easy, i figured i would just go with a different brand driveshaft.
Restricted User
Were the caps on the joint coated ? if not that will be an issue on an AL shaft and cause a problem, vibration or break
