MWC 9" set up? and PST Driveshaft. Vibration
I have had a Midwest Chassis fab 9" in my car for a few months now, put 500 miles on it and 6 passes.
I have the torque arm mounted on the 2nd from the top hole on the Tunnel mount and then I have the LCA's on the 2nd from the bottem on the rear. Is that correct for a non-lowerd car?
I just put in a set of UMI 3-point subframe connectors in it which made me have to redo the pinon. I think I have that set now but I am still getting a vibration, at any speed. I feel a little clunk when I release the clutch, so I looked at my driveshaft. Its a PST driveshaft that I got through Midwest when I ordered the rear. It looks to be out of the tranny a good inch and the driveshaft can be shaken a bit and makes a sound. Could that be my problem?
Thanks
Thanks
It was at all speeds but I haven't been driving it for fear of breaking something.
I'll check those bolts as well. Didn't even think of that.
I havent fixed it yet but I found a problem that I didnt have before. The rear is about a inch too far back so I ordered some adjustable LCA's to bring it forward. Hopefully that will cure the driveshaft issue I had where it was wobbling in the tranny. I'll set the pinion at my shop on Friday on the drive on lift.
One question I have is should the rear tires be centered in the wheel well? or further forward or back?
Thanks for the responses.
Alright. Got adjustable LCA's in tonight and test drove it around the block. Im going to bring it in to my shop tomorrow and allign it. It seems to only happen at low rpm's and at lower speeds. Sometimes steping on it. That would be pinion?
Slight noise. hard to tell cause its so loud. lol
The driveshaft vibration to the tranny is fixed btw.
