U-joint For 9" HELP!
i am putting a 9" in my 02 camaro. i am using the stock 9" yoke and stock driveshaft. my question is, is there a aftermarket u-joint as in lakewood that will fit the stock ds and the 9" yoke. any part numbers or recommendations would be appreciated.
Its called a bastard u-joint I don't know the sizes right off hand but you should be able to pick one up at any driveline shop and Advance usually has them if you know a good counter person you can talk to
Restricted User
Which 9" end yoke are you using, they come with 3 different end yokes...
You could need a 5-793 or a 5-795/792
I would not use any 1330 x 1350 conversion joint in any perf app... though it's your money to wind up doing right in the near future if you do.
