Another 8.8 build
Old 10-08-2010, 04:25 AM
DRAGGIN10's Avatar
Default Another 8.8 build
OK B4 I GET FLOGGED IVE SEARCHED UNTIL MY EYES ARE CROSSED.IM THINKIN ABOUT DOIN A 8.8 BUILD BUT WONDERING WHAT EVERYBODY DID ABOUT THE C-CLIP ELIMINATORS. I WANNA RUN A SPOOL IN THE 8.8 BUT EVERBODY IVE TALKED 2 SAID IF U DO NE DRIVIN THE CLIPS WILL LEAK NE INPUT??????????????
Old 10-08-2010, 05:27 AM
Detroitmuscle's Avatar
I'm curious as well.
Old 10-08-2010, 11:40 PM
DRAGGIN10's Avatar
no takers?
Old 10-09-2010, 02:27 PM
DRAGGIN10's Avatar
dang i figured this would b a easy one for somebody
Old 10-09-2010, 10:33 PM
SoxXpupPeT's Avatar
C-clips will Leak ?? not sure on that one.. Breaking perhaps. If its a drag only car then youd want a c-clip eliminator setup.
Im building an 8.8 (link in sig) but mines a DD and i would prefer to run c-clips (that and strange doesnt make custom length c-clip axles)
I cant see there being a problem if you run a c-clip eliminator and have it "leak".. the engineers at strange have there eliminator setup for oval track. There wont be leaking there..
unless the guys ment the c-clips will break when driving a spool around town.
just my .02
Old 10-10-2010, 01:06 AM
DRAGGIN10's Avatar
thanks 4 the input i take it your not going to run a spool its not really a dd its a weekend ride town cruiser and dragracer i just wanted a locked rear any other good suggestions
Old 10-10-2010, 08:42 PM
SoxXpupPeT's Avatar
Sorry im far from a spool lol. Im going to be running a torsen diff. Abit pricey but its the best you can get. GL with the install
Old 10-16-2010, 03:33 PM
fastsspr's Avatar
You can use 9" ford housing end with the 8.8 build and use the spool with the 9" ends.
Old 10-16-2010, 08:46 PM
DRAGGIN10's Avatar
i had a couple ppl try to get me to do that i just wanted to run the 7.5 tubes for the simplicity of the mounts and brakes already being there
Old 10-16-2010, 08:52 PM
Carl at CRP's Avatar
In response to the op's question, I have found Moser's C-clip eliminators far less prone to leaking than Strange's. Unless the designs have changed Moser's is a one piece with the bearing pressed on and the Strange is a 2-piece.
Ironic part of this Iam a Strange Eng. dealer and not a Moser dealer!
Carl
Old 10-16-2010, 08:56 PM
DRAGGIN10's Avatar
thanks carl
