How much drive shaft play is to much? 1.5 inches?
Old 10-20-2010, 11:37 PM
uphigh07's Avatar
Default How much drive shaft play is to much? 1.5 inches?
ok so i bought a ds off a member on here and put it in my car and the yoke in the tranny is showing about 1 and a half inches i know that they should be atleast 3/4 to a little ove 1 inch but im kinda worry about this as the car makes almost 700hp to the wheels on 10psi.
For more info i have a 12bolt and the tranny is a th400 i mean there is still alot of the yoke on the shaft and in the tranny case but im not sure if this may cause a problem or anything.
Any help would be great!
Old 10-21-2010, 12:14 AM
uphigh07's Avatar
just remembered that i have adj LCA so that will help some, i can move the rear end forward some to help shorten my play in the ds.
Any other idea's
Old 10-21-2010, 06:35 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I would try moving the rear forward about 1/2", as you do want 3/4" to 1.0". Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 10-21-2010, 05:02 PM
uphigh07's Avatar
Ok Thanks bob i will give that a try and hope i can move it that far forward.
Old 10-21-2010, 05:07 PM
BOLO's Avatar
Don't mean to hijack. But Bob, what's the correct driveshaft length center to center?
Old 10-21-2010, 10:54 PM
Restricted User
Supers's Avatar
That depends on the slip yoke also....
Most times you want 1" of play.... but if you have a slip and the ground hub is 7" you can have 3" exposed.
Really depends on a few pieces not just one.
Old 10-22-2010, 03:42 AM
LS1Tech Sponsor
We use the x dimension on the above chart. 10 bolt/12 bolt is 44.25, 9 inch is typically 45.25. Bob
__________________
Old 04-26-2014, 05:22 PM
jt_2002_ta's Avatar
ok i know its a old thread ! so if i got 3/4 to 1" of movement from the transmission shaft backwards after it bottoms out im good ?
We use the x dimension on the above chart. 10 bolt/12 bolt is 44.25", 9 inch is typically 45.25. Bob
mine is 44 3/4" center to center . th400 to 10 bolt. am i ok? there is about 3/4-1"of play. i got a good deal on a used one in town with 1350 u joints and swapped in a napa 447 for the rear. figure if nothing else I can have it shortened but dude said 10 or 12 bolt. and he is active in our local car scene so i doubt he would try to take anyone . thoughts ?
Old 04-26-2014, 06:13 PM
LS1Tech Sponsor
Yup, you're good to go as long as it was in the loaded position when you checked it out. What I mean is the weight is on the rear end. Bob
__________________
Old 04-26-2014, 06:18 PM
jt_2002_ta's Avatar
it was. thank you, i feel much better now!
Old 04-28-2014, 08:54 AM
Firebirdmuscle's Avatar
Hum, I have about 5/8 max out of my tranny when I swapped my rear. If I move the rear back any my rear tires will be rubbing the fender so I stopped. I moved it back forward just enough to get them off the fender just enough. So my wheels aren't quite centered
Quick Reply: How much drive shaft play is to much? 1.5 inches?
