Torque arm mount... trans or tunnel?
What is considered to be best??? I have an Edelbrock non adjustable torque arm right now. Can I use it with a new trans mount keeping it off the trans tailpiece? Or do I really need an adjustable arm???
Should I go with a tunnel mount and shorter adjustable arm?... I have not read whether one or the other is more beneficial to traction or strength and I have searched.
This is with an M6 and S60 rear.
Thanks
any opinions appreciated.
Thanks
LS1Tech Sponsor
I suggest getting the torque arm off the transmission, as when the torque arm is mounted to the transmission it places a huge stress load on the transmissions tailshaft. Broken transmission mounts and even cracked tailshafts have resulted from this stress.
An adjustable torque arm allows the pinion angle to be adjusted to optimize the pinion angle for varying conditions, and I recommend going this route. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
You can buy the relocation crossmember from BMR or UMI that uses a stock full length torque arm but mounts it to the crossmember instead of the tail of the tranny. They are about $240.
Both the short torque arm or long torque arm would work just fine. Deciding what type is based on how you drive the car and what you use it for?
Hope that helps!
Ryan
This would change pinion angle as well but isn't recommended, by moving the torque arm height you are also changing suspension angles such as the instant center point. I would recommend a adjustable torque arm with the relocation crossmember, it allows everything to be set up properly and doesn't leave you regretting not buying adjustable in the first place. Also since you have any aftermarket rear end the adjustable torque arm becomes more important, it insures your drive line angle is correct.
Hope that helps!
Ryan
Hope that helps!
Ryan
Thanks
Thanks Ryan... my entire suspension is slowly becoming entirely UMI... matter of fact I have a trans crossmember with relocation bracket that just left PA today. So I'm going to see if my non-adjustable arm will work and if not it'll be a UMI adjustable full length.
Thanks
Thanks
If you need any help just let us know. Thanks again!
Ryan
