rear differential noise
Old 10-25-2010, 09:29 PM
camaroboy14's Avatar
Default rear differential noise
Hey guys my axle and rear end is mking a lot of noise .I just wanted to know if its common? Also how can I check the fluid and put some in? also when I change the gears will it be less noisy ? Thanks ...
Old 10-25-2010, 09:32 PM
Ruthless909's Avatar
Whining?
Old 10-25-2010, 09:54 PM
Slvr00Bird's Avatar
Welcome to the show..
Old 10-25-2010, 11:24 PM
Pontiacerator
RevGTO's Avatar
If it's whining because wear on the ring and pinion, it'll be better with your new gears. But the carriers themselves can be pretty noisy on these cars without it being a problem. You can check your oil by removing the fill plug. If some starts to drain out, then it's full.
Old 10-25-2010, 11:45 PM
Ok so should I be worried ? Cuz its loud but not too loud...
Old 10-26-2010, 12:56 AM
HoLLo's Avatar
FWIW, a nice fresh fluid change with some quality fluid always seemed to help gear whine a little, but not cure it completely.
Old 10-26-2010, 04:10 PM
Mohican's Avatar
Is it worse around corners. If so you might need new oil and the additive.
Old 10-26-2010, 04:40 PM
Lambert695's Avatar
Nope, my rear end whines all day.. it likes it! Its when you have to wear ear plugs then over the ear protection and drive to the shop with your windows down.. then you know you might want to get it fixed
Old 10-26-2010, 08:27 PM
Ok what fluid should I get! And how many bottles ? And how much does labor cost for fluid change? Also its loud but not too loud! I think it is fluid too because its been about over a year sense I checked the fluid
Old 10-26-2010, 09:30 PM
HoLLo's Avatar
I've always used Royal Purple 75w90. You need 4 quarts (it uses just shy of 4qts). You shouldn't have to be paying anyone for labor, it's very simple actually. Make sure you buy a new gasket and some gasket sealer. You'll also need a razer blade scraper. Make sure you scrape ALL, I mean ALL the gasket material off the diff cover and rear-end, or else you'll be doing it twice. Ask me how I know.
Oddly the only time my rear-end whines is when I let off the gas and coast
Old 10-26-2010, 10:05 PM
Ok great thanks Bro ! Also I am sorry to bug but can you tell me step by step how to do it ? And what tools it is my first time that's why I get nervous
Old 10-26-2010, 10:15 PM
jay_lt4's Avatar
WOW 4 quarts, what are you filling a 1 ton truck rear?? the 7.625" rear holds 1.75 quarts.
Old 10-26-2010, 10:18 PM
Ok so how many guys? Lol I gonna do it bright and early that's why
Old 10-26-2010, 10:20 PM
^^^ Seriously
Mine took a little less than 2qts
Old 10-26-2010, 10:29 PM
ok so 2 quarts now please can some one tell me the steps to do it : ) please
Old 10-26-2010, 10:32 PM
dmuse76's Avatar
Jack the car up, support it. Remove all the diff. cover bolts, after placing a drain pan under it. You may have to pry just a little to get the cover off. after fluid drains, i use brake cleaner to spray off the gears and then a towel to wipe out the bottom of the case. Scrape old gasket off, if it tears when removing cover. if it doesn't you can get by with just putting a little gasket sealer on it. After doing one of those two, reinstall cover. remove fill plug on the side of the housing..(front side close to driveshaft, should be a 3/8 drive extension to take it out) add limited slip additive first, then fill with gear oil until it starts to run out of the hole. Reinstall fill plug, take of off the jack and enjoy!!!!
Old 10-26-2010, 10:37 PM
Nemesis350's Avatar
For the record, whining isn't always gears... A bad bearing(s) can whine too.
Oil for rear is just under 2 quarts.
Old 10-26-2010, 11:10 PM
So I might not need a new gasket
Old 10-26-2010, 11:49 PM
BirdsSince16's Avatar
I'd get one just in case.
Also before you do check to see if the noise is coming from any particular side. If it seems louder from one side than the other, you might have a bearing problem like someone above said. While you have the cover off I'd check the bearings if this is the case. It's actually rather simple as well if you have pretty basic tools. I'd recommend picking up a Haynes or Chilton book if this is the case. (Or get one anyway. They're good to have around.)
This might result in bearing replacement, or if you're unlucky, axle replacement. I'm not saying to do this check right away. Check to see if the noise is side-specific first.
Old 10-27-2010, 12:09 AM
The sound seems coming straight from the middle! The car runs hard and fine
Quick Reply: rear differential noise
