How long to swap in a moser 9"
I just bought a 95 TA drag roller and about the start swapping over the suspension to my 98 Z28.
The 95 has a built moser 9" with an ADJ TQ Arm and I will be taking it out and putting in my car.
The brakes and brackets are still intact on the 95.
I will also be adding Madman LCAs, wolfe single anti-roll, AFCO shocks on all 4 corners, Madman panhard bar, AFCO lower shock brackets.
Any ideas on how long it will take to intall the moser 9" and all new madman suspension parts? 1-2 days?
Should I have to take off my 98 brakes and swap them onto the moser 9" with the current 95 TA brake setup?
Cool deal. I wanted to have it done by the 20th, and all the parts should be here by this friday, so sounds like I should be able to get it done over the coming up weekend.
Just got everything ordered from Steve at Madman's and he was very helpful!
Look forward to leaving on a 150 shot!
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Thank you Steve! Appreciate you taking time to help plan out my suspension.
I'm taking the moser 9" out of the drag roller I bought tomorrow and check everything out while I'm waiting on the parts to come in.
Just have to figure out if the brakes that are on the moser 9" in the 95 will swap over, or if I will have to swap out the 98 LS1 brakes and backing plates.
The best 60' I had with the stock suspension and 10-bolt on 275/60 was 1.65, so with the anti-roll and all new suspension should really improve on motor and especially on spray..
It runs 7.50's in the 1/8 now, and after the new parts and a 150 shot I think that it would go a 6.40 or so.
Have fun with it! I have installation instructions at this link that may help you out. https://www.brutespeed.com/moser_ins...structions.htm Bob
I just bought a D1SC kit, so I will be getting w/ you this winter for a few parts to finish it up after I take off the nitrous.
Yeah I don't think it will be bad at all.
Looks like the Lt1 brakes are going to fit just fine size wise. When I get it out, I will see if the parking brake cables and brake fittings are the same.
Thinking about ordering a 4.30 gear for the rear since I have 28" tall tires. Just need to make sure this would be a good nitrous gear (150-175 shot). I run mainly 1/8 but 1/4 also.
.581 .224 TSP Cam
Stock heads
ls6 intake
headers
stock injectors
air-lid
tune
Nitrous:
NX 15lb bottle
NX warmer
HSW solenoid mounts
FJO controller
MSD Timing Twister
NX lightning soledoids w/ purge
Shark single nozzle
HSW nitrous ashtray switch panel
Start with 100HP jets
Innovate LM1 A/F with pod mount gauge
Transmission:
TCI Super Street Fighter 4l60e
TCI 3000 stall
TCI cooler and fan
Suspension: (only bmr cross member installed now)
Moser 9" w/ 31 splines and detroit locker LT1 rear brakes
3.73 gears ( Thinkiing about swapping for 4.30)
Madman double adjustable LCA'a
Madman Panhard
Wolfe single Anti-roll
AFCO double adjustable shocks FR and Rear
AFCO 300 springs up front
BMR Adj TQ Arm
BMR Cross Member w/ TQ Arm mount
stock rear springs
Subframe connectors
Wolf 6pt cage
On MT ET Street 275/60
Stock heads
ls6 intake
headers
stock injectors
air-lid
tune
Nitrous:
NX 15lb bottle
NX warmer
HSW solenoid mounts
FJO controller
MSD Timing Twister
Shark single nozzle
Transmission:
TCI 3000 stall
TCI cooler and fan
Madman Panhard
BMR Adj TQ Arm
stock rear springs
Subframe connectors
Wolf 6pt cage
I think 4.30 will be too much gear on spray. The 3.90 with a 28" tire looks a lot better. This was it won't be shifting into OD in the 1/4, and should MPH real good on a small shot in 3rd right up to peak power.
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear
500 3 7 11 15
600 4 8 13 18
700 5 9 15 21
800 6 11 17 24
900 6 12 19 27
1000 7 13 21 31
1100 8 15 23 34
1200 8 16 26 37
1300 9 17 28 40
1400 10 18 30 43
1500 10 20 32 46
1600 11 21 34 49
1700 12 22 36 52
1800 13 24 38 55
1900 13 25 41 58
2000 14 26 43 61
2100 15 28 45 64
2200 15 29 47 67
2300 16 30 49 70
2400 17 32 51 73
2500 17 33 53 76
2600 18 34 56 79
2700 19 36 58 82
2800 20 37 60 85
2900 20 38 62 88
3000 21 40 64 92
3100 22 41 66 95
3200 22 42 68 98
3300 23 44 70 101
3400 24 45 73 104
3500 24 46 75 107
3600 25 47 77 110
3700 26 49 79 113
3800 27 50 81 116
3900 27 51 83 119
4000 28 53 85 122
4100 29 54 88 125
4200 29 55 90 128
4300 30 57 92 131
4400 31 58 94 134
4500 31 59 96 137
4600 32 61 98 140
4700 33 62 100 143
4800 34 63 103 146
4900 34 65 105 150
5000 35 66 107 153
5100 36 67 109 156
5200 36 69 111 159
5300 37 70 113 162
5400 38 71 115 165
5500 38 73 117 168
5600 39 74 120 171
5700 40 75 122 174
5800 40 76 124 177
5900 41 78 126 180
6000 42 79 128 183
6100 43 80 130 186
6200 43 82 132 189
500 3 7 11 15
600 4 8 13 18
700 5 9 15 21
800 6 11 17 24
900 6 12 19 27
1000 7 13 21 31
1100 8 15 23 34
1200 8 16 26 37
1300 9 17 28 40
1400 10 18 30 43
1500 10 20 32 46
1600 11 21 34 49
1700 12 22 36 52
1800 13 24 38 55
1900 13 25 41 58
2000 14 26 43 61
2100 15 28 45 64
2200 15 29 47 67
2300 16 30 49 70
2400 17 32 51 73
2500 17 33 53 76
2600 18 34 56 79
2700 19 36 58 82
2800 20 37 60 85
2900 20 38 62 88
3000 21 40 64 92
3100 22 41 66 95
3200 22 42 68 98
3300 23 44 70 101
3400 24 45 73 104
3500 24 46 75 107
3600 25 47 77 110
3700 26 49 79 113
3800 27 50 81 116
3900 27 51 83 119
4000 28 53 85 122
4100 29 54 88 125
4200 29 55 90 128
4300 30 57 92 131
4400 31 58 94 134
4500 31 59 96 137
4600 32 61 98 140
4700 33 62 100 143
4800 34 63 103 146
4900 34 65 105 150
5000 35 66 107 153
5100 36 67 109 156
5200 36 69 111 159
5300 37 70 113 162
5400 38 71 115 165
5500 38 73 117 168
5600 39 74 120 171
5700 40 75 122 174
5800 40 76 124 177
5900 41 78 126 180
6000 42 79 128 183
6100 43 80 130 186
6200 43 82 132 189
Im about to get the same monster going on in my garage, I dont have a lift, but i was lucky enough that my buddy has one, so Im geading to his place to do this...
The link above really helps out!
Thanks
Thanks
So far, I think this will be an easy swap.
Got the moser 9" out of the drag donor in about 45 min with a buddy helping.
I found out it have a competition engineering "short" tunnel mount TQ arm so my y-pipe will have to be modified.
With all the new adjustable suspension, it should be fairly straight forward on centering everything using the panhard and LCA, and pinion angle with the TQ arm.
I'm sure going back in will be more difficult. I thought about putting the LCAs on the 9" and jacking it up to put them in first. I was thinking that will help line it up when putting into the car.
So once its all in, I just need to swap gears, change fluids, get a drive shaft made, and modify the exhaust. Then it should be ready to test.
I'm really impressed with the AFCO shocks.
I don't know what your plans are, but I can get you a custom built drive shaft made from of aluminum, mild steel or chromolly. Aluminum would be the best option, in most cases. Just give me a shout on Monday (or whenever you're ready for it), and I can get you all set up.
