Rear End Shopping
Old 11-09-2010, 12:16 AM
z28Jayp's Avatar
Question Rear End Shopping
i am positive that my rear end on my cutlass supreme is a non posi rear end...i was wondering can i just go buy a 84 camaro rear end from a salvaged lot(cheapest price) and just bolt it right up or do you guys prefer a different rear end ? i am also looking to put bigger gears in the rear and a upgraded trans
Old 11-09-2010, 05:29 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
The G Body rear is completely different from the F Body rear. G-body rears 7.5" or 8.5" are 52.5 in. backing plate to backing plate, and do not use a torque arm. You might get lucky and find a 8.5" rear from a wrecked 1984-1987 Buick Turbo Regal/Grand National, 1984-1987 Oldsmobile 442 or 1984 Hurst/Olds. As far as I know all the other G Body models had either a 7.5" or a 7.62 (Monte Carlo SS) Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 11-09-2010, 10:41 AM
z28Jayp's Avatar
mann someone told me the monte carlo rear end would work...so im guessing i was lied to ?
Old 11-11-2010, 10:13 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
the 7.5 housing internals will swap over, but be sure the axle spline count is the same. the earlier ones were 26 spline, the later ones were 28. as far as the rearend housing itself... no way will any f-body housing made(69-02) will work. you need a 4-link coil-spring type rearend, not a torque arm like the f-body has.
Old 11-11-2010, 03:32 PM
z28Jayp's Avatar
Question
so do you prefer i find a rear end off of another gbody car (montecarlo,elcamino) ?
Old 11-11-2010, 08:17 PM
Zmg00camaross's Avatar
Yes buy a rear for another G-body or rebuild the one you have.
Old 11-11-2010, 09:52 PM
z28Jayp's Avatar
Question
what all does the rebuild consist of for my rear end....would it be cheaper than buying another rear end ?
Old 11-11-2010, 10:26 PM
New gears,bearings, shop around you can find a rebuild kit, also look around for a whole housing out of a car.
Old 11-11-2010, 11:02 PM
flintwrench69's Avatar
If yours has the 10 bolt, which it most likely does I would be looking for an 8.5 inch out of a GN or turbo regal like he said. They are very strong units, nice upgrade & bolts right up.
Old 11-12-2010, 12:09 AM
+badss+'s Avatar
too bad your so far away i have a 8.5 sitting in a monte in my garage with new eaton posi and 4.10 gears and 3 in studs and hotchkis upper/lowers...
Old 11-12-2010, 11:04 AM
z28Jayp's Avatar
man u would be way in florida and im in cali..
Quick Reply: Rear End Shopping
