Install Tips? Strange Going In Friday...
I have my friend who works at a Chevrolet dealership who's doing the install. He's a "spec" mechanic, so I wonder if anyone would like to share any advice being that this guy hasn't done mods.
Any ideas re: the yoke, driveshaft, etc. will be appreciated. I only want to do this once!
8 SEC SLOPPY SHOT!!!
Being a strange you will get the u joint and the rearend come with lube in it already just paint and bolt in and be nice on it for 200 hunded miles for breakin the nicer you are the more quiet the gears will be.
It wasn't my fault either. (Long story, I'll spare you.)
Originally Posted by CANNIBAL
Swapping a rearend is about the easiest thing you can do, It's only held in by a few bolts. Any mechanic worth his tools should be able to knock this out, np.
As Levi noted, the Strange 12-bolt is a very straightforward swap. All of the stock hardware will bolt right back up (no relocation of swaybar, etc., needed). About the only thing you'll need are a spacer and a longer bolt to mount the rear brake line to the housing. Also you'll have to do a little work modifying the factory jumper wires for the ABS sensor since the Strange sensor is different (at least if you have 3-channel ABS - not sure about the 4-channel setup).
